Label | Description |
IPv4 Address Configuration | |
Add | Click this to create a new entry. |
Edit | Double-click an entry or select it and click Edit to be able to modify the entry’s settings. |
Remove | To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Reference | Select an entry and click Reference to check which settings use the entry. |
Name | This field displays the configured name of each address object. |
Type | This field displays the type of each address object. “INTERFACE” means the object uses the settings of one of the Zyxel Device’s interfaces. |
Address | This field displays the IPv4 addresses represented by each address object. If the object’s settings are based on one of the Zyxel Device’s interfaces, the name of the interface displays first followed by the object’s current address settings. |
Reference | This displays the number of times an object reference is used in a profile. |
Name | Type the name used to refer to the address. You may use 2-30 single-byte characters, including 0-9a-zA-Z, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. |
Description | Enter the description associated with the zone, if any. You can use 1 to 30 single-byte characters, including 0-9a-zA-Z. Special characters are not allowed |
Address Type | Select the type of address you want to create. • HOST - the object uses an IP Address to define a host address. • RANGE - the object uses a range address defined by a Starting IP Address and an Ending IP Address. • SUBNET- the object uses a network address defined by a Network IP address and Netmask subnet mask. • INTERFACE IP - the object uses the IP address of one of the Zyxel Device’s interfaces. • INTERFACE SUBNET - the object uses the subnet mask of one of the Zyxel Device’s interfaces. • INTERFACE GATEWAY - the object uses the gateway IP address of one of the Zyxel Device’s interfaces. • GEOGRAPHY - the object uses the IP addresses of a country to represent a country. • FQDN - the object uses the Fully Qualified Domain Name (FQDN) to represent a website. An FQDN consists of a host and domain name. For example, ‘www.zyxel.com.tw’ is a fully qualified domain name, where ‘www’ is the host, ‘zyxel’ is the third-level domain, ‘com’ is the second-level domain, and “tw” is the top level domain. ![]() |
IP Address | This field is only available if the Address Type is HOST. This field cannot be blank. Enter the IP address that this address object represents. |
Starting IP Address | This field is only available if the Address Type is RANGE. This field cannot be blank. Enter the beginning of the range of IP addresses that this address object represents. |
Ending IP Address | This field is only available if the Address Type is RANGE. This field cannot be blank. Enter the end of the range of IP address that this address object represents. |
Network | This field is only available if the Address Type is SUBNET, in which case this field cannot be blank. Enter the IP address of the network that this address object represents. |
Netmask | This field is only available if the Address Type is SUBNET, in which case this field cannot be blank. Enter the subnet mask of the network that this address object represents. Use dotted decimal format. |
Interface | If you selected INTERFACE IP, INTERFACE SUBNET, or INTERFACE GATEWAY as the Address Type, use this field to select the interface of the network that this address object represents. |
Region | If you selected GEOGRAPHY as the Address Type, use this field to select a country or continent. A GEOGRAPHY object uses the data from the country-to-IP/continent-to-IP address database. Go to the Object > Address > Geo IP screen to configure the custom country-to-IP/continent-to-IP address mappings for a GEOGRAPHY object. |
FQDN | This field is only available if the Address Type is FQDN, in which case this field cannot be blank. Enter the FQDN of the website that this address object represents. You can enter a wildcard in the first position. For example, ‘*.zyxel.com’. Click Test to check if the FQDN you entered is valid and to view the result of the DNS query. The Test button is disabled if you enter a FQDN with a wildcard. |
Expire cache by TTL | Enable this to automatically clear the cache when the duration for storing a DNS record in the DNS cache has expired. Disable this if you want to keep the DNS record in the DNS cache after it has expired. |
IPv4 Cache List You must first configure IPv4 FQDN objects in this screen. | |
IP Address | This field displays the mapping of the FQDN to an IP address. This is the IP address of a host. |
TTL | Time to Live (TTL) shows the number of seconds remaining before the DNS record expires. If the Expire cache by TTL option is disabled, the DNS record will not be cleared from the IPv4 Cache List when the TTL expires. The IPv4 Cache List will be updated if the following conditions are met. • The FQDN does not include a wildcard, and • Two minutes after all the TTL (Time To Live)values have expired. |
Apply | Click Apply to save your customized settings and exit this screen. |
Cancel | Click Cancel to return the screen to its last-saved settings. |
IPv4 Address Group Configuration | |
Edit | Select an entry and click Edit to be able to modify the entry’s settings. |
Name | This field displays the name of each address group. |
Description | This field displays the description of each address group, if any. |
Name | Enter a name for the address group. You may use 2-30 single-byte characters, including 0-9a-zA-Z, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. |
Description | You can use 1 to 30 single-byte characters, including 0-9a-zA-Z!”#$%’()*+,-/:;=?@_ &.<>[\]{|}^‘are not allowed. |
Add Object | Click this button to create an address object. See IPv4 Address Add/Edit Screen for more information on configuring an address object. |
Search | Type an item in the search box, then click this to display all address objects in the table below according to the item you typed. |
Select All | Select this to select all address objects and address groups in the table. |
Member List | The list on the left displays the names of the address and address group objects that have been added to the address group. The order of members is not important. Select items fro this list that you want to be members and move them to the list on the right. Move any members you do not want included to the list on the left. ![]() |
Country Database Update | |
Latest Version | This is the latest country-to-IP address database version. |
Current Version | This is the country-to-IP address database version currently on the Zyxel Device. |
Update Now | Click this to check for the latest country-to-IP address database version. The latest version is downloaded to the Zyxel Device and replaces the current version if it is newer. There are logs to show the update status. |
Auto Update | If you want the Zyxel Device to check weekly for the latest country-to-IP address database version, select the checkbox, choose a day and time each week and then click Apply. |
Custom IPv4 to Geography Rules | Enter an IP address, then click the IPv4 to Geography button to query which country this IP address belongs to. |
Name | This filed displays the name of the entry. |
Geolocation | This field displays the name of the country or region that is associated with this IP address. |
Type | This field displays whether this address object is HOST, RANGE or SUBNET. |
IPv4 Address | This field displays the IPv4/IPv6 addresses represented by the type of address object. |
Region vs. Continent | |
Region vs. Continent | Enter a country or continent name in the Search field to query which continent this country belongs to or which countries belong to the continent. |
Region | Select the country or continent that maps to this IP address. |
Address Type | Select the type of address you want to create. Choices are: HOST, RANGE, CIDR. |
IP Starting Address | This field is only available if the Address Type is RANGE. This field cannot be blank. Enter the beginning of the range of IP addresses that this address object represents. |
IP Ending Address | This field is only available if the Address Type is RANGE. This field cannot be blank. Enter the end of the range of IP address that this address object represents. |
Network / Netmask | These fields are only available if the IPv4 Address Type is SUBNET. They cannot be blank. Enter the network IP and subnet mask that defines the IPv4 subnet. |
Name | This identifies the object for which the configuration settings that use it are displayed. Click the object’s name to display the object’s configuration screen in the main window. |
# | This field is a sequential value, and it is not associated with any entry. |
Service | This is the type of setting that references the selected object. Click a service’s name to display the service’s configuration screen in the main window. |
Priority | If it is applicable, this field displays the referencing configuration item’s position in its list; otherwise - displays. |
Name | This field identifies the configuration item that references the object. |
Description | If the referencing configuration has a description configured, it displays here. |
Refresh | Click this to update the information in this screen. |
Cancel | Click this to close the screen. |
Name | This field displays the name of each service. |
Content | This field displays a description of each service. |
Name | Type the name used to refer to the service. You may use 1-30 single-byte characters, including 0-9a-zA-Z!”#$%’()*+,-/:;=?@_, but the first character cannot be a number. &.<>[\]{|}^‘are not allowed. This value is case-sensitive. |
Description | Type the description used to refer to the service. You may use 1-30 single-byte characters, including 0-9a-zA-Z!”#$%’()*+,-/:;=?@_, but the first character cannot be a number. &.<>[\]{|}^‘are not allowed. |
IP Protocol | Select the protocol the service uses. Choices are: TCP, UDP, ICMP, ICMPv6, and User Defined. |
Starting Port Ending Port | This field appears if the IP Protocol is TCP or UDP. Specify the port number(s) used by this service. If you fill in one of these fields, the service uses that port. If you fill in both fields, the service uses the range of ports. |
ICMP Type | This field appears if the IP Protocol is ICMP or ICMPv6. Select the ICMP message used by this service. This field displays the message text, not the message number. |
IP Protocol Number | This field appears if the IP Protocol is User Defined. Enter the number of the next-level protocol (IP protocol). Allowed values are 1 - 255. |
Name | This field displays the name of each service group. By default, the Zyxel Device uses services starting with “Default_Allow_” in the security policies to allow certain services to connect to the Zyxel Device. |
Description | This field displays the description of each service group, if any. |
Name | Type the name used to refer to the service group. You may use 1-30 single-byte characters, including 0-9a-zA-Z!”#$%’()*+,-/:;=?@_, but the first character cannot be a number. &.<>[\]{|}^‘are not allowed. This value is case-sensitive. |
Description | Type the description used to refer to the service group. You may use 1-30 single-byte characters, including 0-9a-zA-Z!”#$%’()*+,-/:;=?@_, but the first character cannot be a number. &.<>[\]{|}^‘are not allowed. |
Member List | This list displays the names of the service and service group objects that have been added to the service group. The order of members is not important. Select items from the list on the left that you want to be members and move them to the list on the right. Move any members you do not want included to the list on the left. |
User Configuration | The Zyxel Device comes with pre-configured system default zones that you cannot delete. You can create your own zones by clicking Add. |
Add | Click this to create a new, user-configured zone. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. |
Remove | To remove a user-configured trunk, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Name | This field displays the name of the zone. |
Members | This field displays the names of the interfaces that belong to each zone. |
Description | This field displays the description of the zone. |
Reference | This field displays the number of times an Object Reference is used in a policy. |
Name | For a system default zone, the name is read only. For a user-configured zone, type the name used to refer to the zone. You may use 2-30 single-byte characters, including 0-9a-zA-Z_.-, but the first character cannot be a number. This value is case-sensitive. |
Description | Enter the description associated with the zone, if any. You can use 1 to 30 single-byte characters, including 0-9a-zA-Z!”#$%’()*+,-/:;=?@_ &.<>[\]{|}^‘are not allowed. |
Member List | The list on the left displays the interfaces and VPN tunnels that do not belong to any zone. Select the interfaces and VPN tunnels that you want to add to the zone you are editing, and click the right arrow button to add them. The list on the right displays the interfaces and VPN tunnels that belong to the zone. Select any interfaces that you want to remove from the zone, and click the left arrow button to remove them. |
One Time | |
Name | This field displays the name of the schedule, which is used to refer to the schedule. |
Start Day / Time | This field displays the date and time at which the schedule begins. |
Stop Day / Time | This field displays the date and time at which the schedule ends. |
Recurring | |
Start Time | This field displays the time at which the schedule begins. |
Stop Time | This field displays the time at which the schedule ends. |
Configuration | |
Name | Type the name used to refer to the one-time schedule. You may use 2-30 single-byte characters, including 0-9a-zA-Z, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. |
Description | Type a description used to identify the one-time schedule. You may use 1-30 single-byte characters, including 0-9a-zA-Z’()+,/:=?;!*#@$_%-” |
Day Time | |
Start | Specify the year, month, and day when the schedule begins. • Year - 1900 - 2999 • Month - 1 - 12 • Day - 1 - 31 (it is not possible to specify illegal dates, such as February 31.) Specify the hour and minute when the schedule begins. • Hour - 1-12 AM/PM • Minute - 0 - 59 |
Stop | Specify the year, month, and day when the schedule ends. • Year - 1900 - 2999 • Month - 1 - 12 • Day - 1 - 31 (it is not possible to specify illegal dates, such as February 31.) Specify the hour and minute when the schedule ends. • Hour - 1-12 AM/PM • Minute - 0 - 59 |
Configuration | |
Name | Type the name used to refer to the recurring schedule. You may use 2-30 single-byte characters, including 0-9a-zA-Z, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. |
Date Time | |
StartTime | Specify the hour and minute when the schedule begins each day. Then, select each day of the week the recurring schedule is effective. • Hour - 1-12 AM/PM • Minute - 0 - 59 |
StopTime | Specify the hour and minute when the schedule ends each day. Then, select each day of the week the recurring schedule is effective. • Hour - 1-12 AM/PM • Minute - 0 - 59 |
Configuration | |
Name | This field displays the name of the schedule group, which is used to refer to the schedule. |
Description | This field displays the description of the schedule group. |
Members | This field lists the members in the schedule group. Each member is separated by a comma. |
Group Members | |
Description | Enter a description of the service group, if any. You can use 1 to 30 single-byte characters, special characters and spaces are allowed. |
Member List | |
