DSCP (6 bits) | Unused (2 bits) |
Class 1 | Class 2 | Class 3 | Class 4 | |
Low Drop Precedence | AF11 (10) | AF21 (18) | AF31 (26) | AF41 (34) |
Medium Drop Precedence | AF12 (12) | AF22 (20) | AF32 (28) | AF42 (36) |
High Drop Precedence | AF13 (14) | AF23 (22) | AF33 (30) | AF43 (38) |
Label | Description |
Use IPv4 Policy Route to Override Direct Route | Select this to have the Zyxel Device forward packets that match a policy route according to the policy route instead of sending the packets directly to a connected network. |
Add | Click this to create a new entry. Select an entry and click Add to create a new entry after the selected entry. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. |
Remove | To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Active | Select one or more policies, then click this to enable the selected policies. The Status light changes accordingly. |
Inactive | Select one or more policies, then click this to disable the selected policies. The Status light changes accordingly. |
Move to | Select a policy, click this, enter a new location up to and including the last policy number, then press [ENTER] to move it to the new location. Policies are checked in order beginning from the first. |
Search | Type an item in the search box, then click this to display all sessions in the table below according to the item you typed. |
Clear All | Click this to remove all items found in the search. |
Filter | Click the Filter icon ![]() |
Status | This icon is lit when the entry is active, red when the next hop’s connection is down, and dimmed when the entry is inactive. |
Priority | This is the row number of the policy. Policies are checked in order beginning from the first. |
User | This is the name of the user (group) object from which the packets are sent. any means all users. |
Schedule | This is the name of the schedule object. any means the route is active at all times if enabled. |
Incoming | This is the interface on which the packets are received. |
Source | This is the name of the source IP address (group) object, including geographic address and FQDN (group) objects. any means all IP addresses. |
Destination | This is the name of the destination IP address (group) object, including geographic and FQDN (group) address objects. any means all IP addresses. |
DSCP Code | This is the DSCP value of incoming packets to which this policy route applies. any means all DSCP values or no DSCP marker. default means traffic with a DSCP value of 0. This is usually best effort traffic The “af” entries stand for Assured Forwarding. The number following the “af” identifies one of four classes and one of three drop preferences. See Assured Forwarding (AF) PHB for DiffServ for more details. |
Service | This is the name of the destination service object. any means all destination services. |
Source Port | This is the name of the source service object. any means all source services. |
Next-Hop | This is the next hop to which packets are directed. It helps forward packets to their destinations and can be an IP address of a router or a VTI interface. |
DSCP Marking | This is how the Zyxel Device handles the DSCP value of the outgoing packets that match this route. If this field displays a DSCP value, the Zyxel Device applies that DSCP value to the route’s outgoing packets. preserve means the Zyxel Device does not modify the DSCP value of the route’s outgoing packets. default means the Zyxel Device sets the DSCP value of the route’s outgoing packets to 0. The “af” choices stand for Assured Forwarding. The number following the “af” identifies one of four classes and one of three drop preferences. See Assured Forwarding (AF) PHB for DiffServ for more details. |
SNAT | This is the source IP address that the route uses. It displays none if the Zyxel Device does not perform NAT for this route. |
Hits | This is the number of sessions with traffic that matched the policy criteria. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to return the screen to its last-saved settings. |
Enable | Select this to activate the rule. |
Name | Enter a name to identify this rule. |
Description | Enter a descriptive name consists of 1 to 60 single-byte characters, including a-zA-Z0-9. Special characters and spaces are allowed. |
Criteria | |
User | Select a user name or user group from which the packets are sent. |
Incoming | Select where the packets are coming from; any, an interface, a tunnel, an SSL VPN, or the Zyxel Device itself. For an interface, a tunnel, or an SSL VPN, you also need to select the individual interface, VPN tunnel, or SSL VPN connection. |
Source Address | Select a source IP address object, including geographic address and FQDN (group) objects, from which the packets are sent. |
Destination Address | Select a destination IP address object, including geographic address and FQDN (group) objects, to which the traffic is being sent. If the next hop is a dynamic VPN tunnel and you enable Auto Destination Address, the Zyxel Device uses the local network of the peer router that initiated an incoming dynamic IPSec tunnel as the destination address of the policy instead of your configuration here. |
DSCP Code | Select a DSCP code point value of incoming packets to which this policy route applies or select User Define to specify another DSCP code point. The lower the number the higher the priority with the exception of 0 which is usually given only best-effort treatment. any means all DSCP value or no DSCP marker. default means traffic with a DSCP value of 0. This is usually best effort traffic The “af” choices stand for Assured Forwarding. The number following the “af” identifies one of four classes and one of three drop preferences. See Assured Forwarding (AF) PHB for DiffServ for more details. |
User-Defined DSCP Code | Use this field to specify a custom DSCP code point when you select User Define in the previous field. |
Schedule | Select a schedule to control when the policy route is active. none means the route is active at all times if enabled. |
Service | Select a destination service or service group to identify the type of traffic to which this policy route applies. |
Source Port | Select a source service or service group to identify the source port of packets to which the policy route applies. |
Next-Hop | |
Type | Select Auto to have the Zyxel Device use the routing table to find a next-hop and forward the matched packets automatically. Select Interface to route the matched packets through the specified outgoing interface to a gateway (which is connected to the interface). Select gateway to route the matched IPv6 packets through a 6to4 tunnel to the packets’ destination. Select gateway-ip to route the matched packets to the next-hop router or switch you specified in the Host IP Address field. You have to set up the next-hop router or switch as a HOST address object first. Select trunk to route the matched packets through the interfaces in the trunk group based on the load balancing algorithm. |
Interface | This field displays when you select Interface in the Type field. Select an interface to have the Zyxel Device send traffic that matches the policy route through the specified interface. |
Service | This field displays when you select gateway in the Type field. IP6to4-Relay service enables IPv6 packets to cross IPv4 networks; see What You Need to Know for more information. |
Host IP Address | This field displays when you select gateway-ip in the Type field. Select a HOST address object. The gateway is an immediate neighbor of your Zyxel Device that will forward the packet to the destination. The gateway must be a router or switch on the same segment as your Zyxel Device's interface(s). |
Trunk | This field displays when you select trunk in the Type field. Select a trunk group to have the Zyxel Device send the packets via the interfaces in the group. |
DSCP Marking | Set how the Zyxel Device handles the DSCP value of the outgoing packets that match this route. Select one of the pre-defined DSCP values to apply or select User Define to specify another DSCP value. The “af” choices stand for Assured Forwarding. The number following the “af” identifies one of four classes and one of three drop preferences. See Assured Forwarding (AF) PHB for DiffServ for more details. Select preserve to have the Zyxel Device keep the packets’ original DSCP value. Select default to have the Zyxel Device set the DSCP value of the packets to 0. |
User-Defined DSCP Marking | Use this field to specify a custom DSCP value. |
Address Translation | Use this section to configure NAT for the policy route. This section does not apply to policy routes that use a VPN tunnel as the next hop. |
Source Network Address Translation | Select none to not use NAT for the route. Select outgoing-interface to use the IP address of the outgoing interface as the source IP address of the packets that matches this route. To use SNAT for a virtual interface that is in the same WAN trunk as the physical interface to which the virtual interface is bound, the virtual interface and physical interface must be in different subnets. Otherwise, select a pre-defined address (group) to use as the source IP address(es) of the packets that match this route. |
Add | Click this to create a new static route. |
Name | This is the name of the static route entry. |
Destination | This is the destination IP address. |
Next-Hop | This is the IP address of the next-hop gateway or the interface through which the traffic is routed. The gateway is a router or switch on the same segment as your Zyxel Device's interface(s). The gateway helps forward packets to their destinations. |
Metric | This is the route’s priority among the Zyxel Device’s routes. The smaller the number, the higher priority the route has. |
Name | Enter a name to identify this rule. You can use up to 30 single-byte characters, including 0-9a-zA-Z. The first character cannot be a number. |
Destination | This parameter specifies the IP network address of the final destination. Routing is always based on network number. If you need to specify a route to a single host, enter the specific IP address here. |
Next Hop | |
Gateway | Select the radio button and enter the IP address of the next-hop gateway. The gateway is a router or switch on the same segment as your Zyxel Device's interface(s). The gateway helps forward packets to their destinations. |
Gateway Object | Select the radio button to route the matched IPv6 packets through a 6to4 tunnel to the packets’ destination. |
Interface | Select the radio button and a predefined interface through which the traffic is sent. |
Metric | Metric represents the “cost” of transmission for routing purposes. IP routing uses hop count as the measurement of cost, with a minimum of 1 for directly connected networks. Enter a number that approximates the cost for this link. The number need not be precise, but it must be 0~127. In practice, 2 or 3 is usually a good number. |
