Object Type | Object screen | Description |
User Accounts | User Account/ User Group | Configure a user account or user group to which you want to apply this SSL access policy. |
Application | SSL Application | Configure an SSL application object to specify the type of application and the address of the local computer, server, or web site SSL users are to be able to access. |
IP Pool | Address | Configure an address object that defines a range of private IP addresses to assign to user computers so they can access the internal network through a VPN connection. |
Server Addresses | Address | Configure address objects for the IP addresses of the DNS and WINS servers that the Zyxel Device sends to the VPN connection users. |
VPN Network | Address | Configure an address object to specify which network segment users are allowed to access through a VPN connection. |
label | description |
Enable | Click the switch to enable the SSL access policy. |
Download | Click to download a VPN configuration script to send to clients using SecuExtender VPN client or OpenVPN Connect VPN client. The supported operating systems for SecuExtender are: • Windows 10 (64-bit) and later versions. • macOS 10.15 and later versions. |
Incoming Interface | |
Interface | Select an interface from the drop-down list box for incoming traffic to your Zyxel Device. |
DNS Name | Enter the domain name (for example, vpn.zyxel.com) if you’re using DDNS to assign the interface a dynamic IP address. |
Server Port | Specify the server port of the Zyxel Device for full tunnel mode SSL VPN access. Leave this field to default settings unless it conflicts with another interface. |
Local Network | |
Full Tunnel | Select Full Tunnel to encrypt all traffic through the VPN. Select Allow Client VPN Traffic Through WAN to allow only traffic encrypted by the Zyxel Device from the remote client to the Internet. |
Split Tunnel | Select Split Tunnel to only encrypt traffic going to networks behind the Zyxel Device. Enter an IPv4 address in CIDR notation, for example, type 192.168.1.1/24. Traffic going to the Internet from this IP address is encrypted. Traffic going to the Internet from the remote client does not go through the Zyxel Device is not encrypted. |
Client Network | |
IP Address Pool | Enter an IPv4 address in CIDR notation, for example, type 192.168.1.1/24. The IP address pool is used to assign IP addresses to the VPN clients. The SSL VPN IP pool should not overlap with IP addresses on the Zyxel Device's local networks and the SSL user's network. |
First DNS Server | Specify the IP address of the DNS server whose information the Zyxel Device sends to the remote users. This allows them to access devices on the local network using domain names instead of IP addresses. ZyWALL- the VPN clients use the IP address of the interface you specified in the SSL VPN rule and the Zyxel Device works as a DNS relay. Custom Defined- enter a static IPv4 address |
Second DNS Server | Enter a secondary DNS server IP address that is checked if the first one is unavailable. |
Authentication | You must first create a server in User & Authentication > AAA Server for it to display in the following fields. • If you have one authentication server, it can be on the Zyxel Device (local) or an external AAA server. • If you have two authentication servers, one of them must be on the Zyxel Device (local). You cannot use two external AAA servers. |
Primary/Secondary Server | Select local or a specified AAA server from the drop-down list box for the Zyxel Device to use for authentication. |
User | Select a user or user group to associate with this SSL access policy. |
Advanced Settings | |
Generate Certificate | Click the button to have the Zyxel Device generate a certificate from the current SSL VPN settings. This is the certificate the Zyxel Device uses to identify itself when setting up the SSL VPN tunnel. If you change the SSL VPN settings, the Generate Certificate button displays. Click Generate Certificate to generate a new certificate from the new SSL VPN settings. Please note that VPN clients cannot connect to the SSL VPN tunnel while the Zyxel Device is generating certificate. If you change the SSL VPN settings and generate a new certificate from the new SSL VPN settings, all connected SSL VPN clients have to update their SSL VPN settings so their SSL VPN settings match the Zyxel Device SSL VPN settings. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving. |
