SSL Inspection
Secure Socket Layer (SSL) traffic, such as https://www.google.com/HTTPS, FTPs, POP3s, SMTPs, and so on, is encrypted, and cannot be inspected using Security Service profiles such as App Patrol, Web Filtering, Intrusion Prevention System (IPS), or Anti-Malware. The Zyxel Device uses SSL Inspection to decrypt SSL traffic, sends it to the Security Service engines for inspection, then encrypts traffic that passes inspection and forwards it to the destination server, such as Google.
Use the Security Service > SSL Inspection > Profile screen (The SSL Inspection Profile Screen) to view SSL Inspection profiles. Click the Add or Edit icon in this screen to configure the CA certificate, action and log in an SSL Inspection profile.
Use the Security Service > SSL Inspection > Exclude List screens (Exclude List Screen) to create a whitelist of destination servers to which traffic is passed through uninspected.
Use the Security Service > SSL Inspection > Certificate Update screens (Certificate Update Screen) to update the latest certificates of servers using SSL connections to the Zyxel Device network
What You Need To Know
SSL Inspection supports the following TLS protocols and encryption algorithms
TLS1.0 AES-CBC
TLS1.2 AES-CBC/AES-GCM
TLS 1.3
SSL Inspection does not support the following:
Compression Support
Client Authentication
Before You Begin
If you don’t want to use the default Zyxel Device certificate, then create a new certificate in Object > Certificate > My Certificates.
Decide what destination servers to which traffic is sent directly without inspection. This may be a matter of privacy and legality regarding inspecting an individual’s encrypted session, such as financial websites. This may vary by locale.
An SSL Inspection profile is a template with pre-configured certificate, action and log.
The following table describes the fields in this screen.
label
Description
General Settings
Server Signed Certificate Key Mode
With SSL inspection, the acts as a 'man-in-the-middle' between a client and a remote server, when the client and server are communicating using an SSL-encrypted session. Every time the client and server send data to each other, the decrypts the sender’s encrypted data, scans the plain data for threats, re-encrypts the data, and then sends the encrypted data to the receiver.
For outgoing sessions from the client to the remote server, the creates a virtual server to decrypt data and a virtual client to re-encrypt data.
For incoming sessions from the remote server to the client, the creates a virtual client to decrypt data, and a virtual server to re-encrypt data.
To perform SSL Inspection for clients using SSL (HTTPS, SSH, SMTP) through the , the must check that the server’s certificate with corresponding public key are valid and were issued by a Certificate Authority (CA) listed in the Zyxel Device's list of trusted CAs. According to the selected key mode RSA 1024, RSA 2048, ECDSA-RSA-1024 or ECDSA-RSA-2048, the will construct the corresponding self-signed certificate for the virtual server.
RSA is a public-key cryptosystem used for data encryption or signing messages. For data encryption, the encryption key is public and the decryption key is private. For signing messages, the signing key is private and the verification key is public. Elliptic Curve Cryptography (ECC) is a public-key cryptosystem based on elliptic curve theory, and more efficient than RSA. ECC allows smaller keys compared to RSA to provide equivalent security. For example, a 224-bit elliptic curve public key should provide comparable security to a 2048-bit RSA public key.
ECDSA-RSA-1024 indicates support for clients that support both ECDSA-256 and RSA-1024 with ECDSA-256 having higher priority, that is ECDSA-256 is used by the virtual server, if a client supports both ECDSA-256 and RSA-1024.
ECDSA-RSA-2048 indicates support for clients that support both ECDSA-256 and RSA-2048 with ECDSA-256 having higher priority, that is ECDSA-256 is used by the virtual server, if a client supports both ECDSA-256 and RSA-2048.
Select a mode that the client’s browser, FTP client, or mail client supports. The will use different keys (cryptosystems) for each client according to the client’s support list.
For example, if there are three clients behind a with the following key mode support:
Client 1 - RSA-1024
Client 2 - RSA-2048 and RSA-1024
Client 3 - ECDSA-256 and RSA-2048.
If you set the key mode to ECDSA-RSA-1024, then the following will be used by each client:
Client 1 - RSA-1024
Client 2 - RSA-1024
Client 3 - ECDSA-256.
If you set the key mode to ECDSA-RSA-2048, then the following will be used by each client:
Client 1 - sessions will not be processed (pass) by SSL inspection
Client 2 - RSA-2048
Statistics
Enable this to have the Zyxel Device collect SSL inspection statistics.
Profile Management
Add
Click Add to create a new profile.
Edit
Select an entry and click this to be able to modify it.
Remove
Select an entry and click this to delete it.
References
Select an entry and click References to open a screen that shows which settings use the entry.
Action
Click this icon to apply the entry to a policy control rule.
Go to the Security Policy > Policy Control screen to check the result.
This is the entry’s index number in the list.
Name
This displays the name of the profile.
Description
This displays the description of the profile.
CA Certificate
This displays the CA certificate being used in this profile.
Reference
This displays the number of times an object reference is used in a profile.
Add/Edit SSL Inspection Profiles
Security Service > SSL Inspection > Profile > Add/Edit
LABEL
Description
Name
This is the name of the profile. You may use 1-31 alphanumeric characters, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. These are valid, unique profile names:
MyProfile
mYProfile
Mymy12_3-4
These are invalid profile names:
1mYProfile
My Profile
MyProfile?
Whatalongprofilename123456789012
Description
Enter additional information about this SSL Inspection entry. You can enter up to 60 characters (0-9a-zA-Z’()+:=?;!*#@$_%-”). The first character must be a letter.
CA Certificate
This contains the default certificate and the certificates created in Object > Certificate > My Certificates. Choose the certificate for this profile.
Email
Use this button to have the Zyxel Device send the selected certificate to a valid email address.
Click a certificate’s row to select it and click Email to have the Zyxel Device mail that certificate. The following screen displays.
Email Subject
Enter a email subject text with 1-60 characters. It may consist of letters, numbers, and the following special characters: ‘()+,./:=?;!*#@$%-
Email to
Enter up to 83 characters for the email address of the receiver
Email Content
Enter the backup email body text using 1 to 251 single-byte characters, including 0-9a-zA-Z!”#$%&’()*+,-./:;<=>@[\]^_‘{|} and spaces are allowed.
? is not allowed.
Cancel
Click this to send the email to the email address you configured.
Send Email
Click this to close the screen.
SSL/TLS version
Minimum Support
SSL / TLS connections using versions lower than this setting are blocked.
Log
These are the log options for unsupported traffic that matches traffic bound to this policy:
no: Select this option to have the Zyxel Device create no log for unsupported traffic that matches traffic bound to this policy.
log: Select this option to have the Zyxel Device create a log for unsupported traffic that matches traffic bound to this policy
log alert: An alert is an emailed log for more serious events that may need more immediate attention. They also appear in red in the Log & Report > Log/Events screen. Select this option to have the Zyxel Device send an alert for unsupported traffic that matches traffic bound to this policy.
Unsupported suit
Action
SSL Inspection supports these cipher suites:
DES
3DES
AES
Select to pass or block unsupported traffic (such as other cipher suites, compressed traffic, client authentication requests, and so on) that matches traffic bound to this policy here.
Log
Untrusted cert chain
Action
A certificate chain is a certification process that involves the following certificates between the SSL/TLS server and a client. A certificate chain will fail if one of the following certificates is not correct.
A certificate owned by a user
The certificate signed by a certification authority
A root certificate
Select to pass, inspect, or block an untrusted certification chain.
Log
Apply
Click Apply to save your settings to the Zyxel Device, and return to the profile summary page.
Reset
Click Reset to return to the profile summary page without saving any changes.
Exclude List Screen
There may be privacy and legality issues regarding inspecting a user's encrypted session. The legal issues may vary by locale, so it's important to check with your legal department to make sure that it’s OK to intercept SSL traffic from your Zyxel Device users.
To ensure individual privacy and meet legal requirements, you can configure an exclusion list to exclude matching sessions to destination servers. This traffic is not intercepted and is passed through uninspected.
LABEL
Description
General Settings
Enable Logs for Exclude List
Click this to create a log for traffic that bypasses SSL Inspection.
Exclude List Address Settings
Use this part of the screen to create, edit, or delete items in the SSL Inspection exclusion list.
Add
Click this to create a new entry.
Edit
Remove
Select a row and click this to delete it.
Content
SSL traffic to a server to be excluded from SSL Inspection is identified by its certificate. Identify the certificate in one of the following ways:
The Common Name (CN) of the certificate. The common name of the certificate can be created in the System > Certificate > My Certificates screen.
Type an IPv4 address. For example, type 192.168.1.35
Type an IPv4 in CIDR notation. For example, type 192.168.1.1/24
Type an IPv4 address range. For example, type 192.168.1.1-192.168.1.35
Type an email address. For example, type abc@zyxel.com.tw
Type a DNS name or a common name (wildcard char: '*', escape char: '\'). Use up to 127 case-insensitive characters (0-9a-zA-Z`~!@#$%^&*()-_=+[]{}\|;:',.<>/?). ‘*’ can be used as a wildcard to match any string. Use ‘\*’ to indicate a single wildcard character.
Apply
Click Apply to save your settings to the Zyxel Device.
Cancel
Click Cancel to return to the profile summary page without saving any changes.
Use this screen to update the latest certificates of servers using SSL connections to the Zyxel Device network.
Security Services > SSL Inspection > Certificate Update
LABEL
Description
Certificate Information
Current Version
This displays the current certificate set version.
Released Date
This field displays the date and time the current certificate set was released.
Certificate Update
You should have Internet access and have activated SSL Inspection on the Zyxel Device at NCC.
Update Now
Click this button to download the latest certificate set (Windows, MAC OS X, and Android) from the Zyxel cloud server and update it on the Zyxel Device.
Auto Update
Select this to automatically have the Zyxel Device update the certificate set when a new one becomes available on the Zyxel cloud server.
Apply
Cancel
