From Zone to Zone | Behavior |
From any to Device | DHCP traffic from any interface to the Zyxel Device is allowed. |
From LAN1 to any (other than the Zyxel Device) | Traffic from the LAN1 to any of the networks connected to the Zyxel Device is allowed. |
From LAN2 to any (other than the Zyxel Device) | Traffic from the LAN2 to any of the networks connected to the Zyxel Device is allowed. |
From LAN1 to Device | Traffic from the LAN1 to the Zyxel Device itself is allowed. |
From LAN2 to Device | Traffic from the LAN2 to the Zyxel Device itself is allowed. |
From WAN to Device | The default services listed in To-Device Policies are allowed from the WAN to the Zyxel Device itself. All other WAN to Zyxel Device traffic is dropped. |
From any to any | Traffic that does not match any Security policy is dropped. This includes traffic from the WAN to any of the networks behind the Zyxel Device. This also includes traffic to or from interfaces that are not assigned to a zone (extra-zone traffic). |
Label | Description |
General Settings | Enable or disable the policy control feature on the Zyxel Device. |
Allow Asymmetrical Route | If an alternate gateway on the LAN has an IP address in the same subnet as the Zyxel Device’s LAN IP address, return traffic may not go through the Zyxel Device. This is called an asymmetrical or “triangle” route. This causes the Zyxel Device to reset the connection, as the connection has not been acknowledged. Select this check box to have the Zyxel Device permit the use of asymmetrical route topology on the network (not reset the connection). ![]() |
Add | Click this to create a new entry. Select an entry and click Add to create a new entry after the selected entry. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. |
Remove | To remove an entry, select it and click Remove. The Zyxel Device confirms if you want to remove it before doing so. |
Active | To turn on an entry, select it and click Activate. |
Inactive | To turn off an entry, select it and click Inactivate. |
Move to | To change a policy’s position in the numbered list, select the policy and click Move to display a field to type a number for where you want to put that policy and press [ENTER] to move the policy to the number that you typed. The ordering of your policies is important as they are applied in order of their numbering. |
Copy to | You can create a new policy by copying an existing one to a new position, and then editing it. Select an existing policy and click Copy to display a field to type a number for where you want to put that policy, then press [ENTER] to copy the policy to the number that you typed. After copying it, edit it to change it from the one copied. |
Search | Type an item in the search box, then click this to display all sessions in the table below according to the item you typed. |
Clear All | Click this to remove all items found in the search. |
Filter | Click the Filter icon ![]() |
The following read-only fields summarize the policies you have created that apply to traffic traveling in the selected packet direction. | |
Status | This icon is lit when the entry is active and dimmed when the entry is inactive. |
Priority | This is the position of your Security Policy in the global policy list (including all through-Zyxel Device and to-Zyxel Device policies). The ordering of your policies is important as policies are applied in sequence. Default displays for the default Security Policy behavior that the Zyxel Device performs on traffic that does not match any other Security Policy. |
Name | This is the name of the Security policy. |
From / To | This is the direction of travel of packets. Select from which zone the packets come and to which zone they go. Security policies are grouped based on the direction of travel of packets to which they apply. For example, from LAN to LAN means packets traveling from a computer or subnet on the LAN to either another computer or subnet on the LAN. From any displays all the security policies for traffic going to the selected To Zone. To any displays all the security policies for traffic coming from the selected From Zone. From any to any displays all of the security policies. To ZyWALL policies are for traffic that is destined for the Zyxel Device and control which computers can manage the Zyxel Device. |
Source | This displays the IPv4 source address object, including geographic address and FQDN (group) objects, to which this Security Policy applies. |
Destination | This displays the IPv4 destination address object, including geographic address and FQDN (group) objects, to which this Security Policy applies. |
Service | This displays the service object to which this security policy applies. |
User | This is the user name or user group name to which this security policy applies. |
Schedule | This field tells you the schedule object that the policy uses. none means the policy is active at all times if enabled. |
Action | This field displays whether the security policy silently discards packets without notification (deny), permits the passage of packets (allow) or drops packets with notification (reject) |
Log | Select whether to have the Zyxel Device generate a log (log), log and alert (log alert) or not (no) when the policy is matched to the criteria listed above. |
Profile | This field shows you which security service profiles (application patrol, content filter and SSL inspection) apply to the policy control rule. Click the icon to edit the profile directly. |
Enable | Select this check box to activate the policy control. |
Name | Type a name with 1 to 30 single-byte characters to identify the policy, including a-zA-Z0-9. Special characters and spaces are not allowed. |
Description | Enter a descriptive name of 1 to 30 single-byte characters for the policy, including spaces and 0-9a-zA-Z!”#$%()*+,-/:;=?@_ &.<>[\]^‘{|} are not allowed. |
From To | For through-Zyxel Device policies, select the direction of travel of packets to which the policy applies. any means all interfaces. ZyWALL means packets destined for the Zyxel Device itself. |
Source | Select an IPv4 address or address group object, including geographic address and FQDN (group) objects, to apply the policy to traffic coming from it. Select any to apply the policy to all traffic coming from IPv4 addresses. ![]() |
Destination | Select an IPv4 address or address group, including geographic address and FQDN (group) objects, to apply the policy to traffic going to it. Select any to apply the policy to all traffic going to IPv4 addresses. |
Service | Select a service or service group from the drop-down list box. |
User | This field is not available when you are configuring a to-Zyxel Device policy. Select a user name or user group to which to apply the policy. The Security Policy is activated only when the specified user logs into the system and the policy will be disabled when the user logs out. Otherwise, select any and there is no need for user logging. ![]() |
Schedule | Select a schedule that defines when the policy applies. Otherwise, select none and the policy is always effective. |
Action | Use the drop-down list box to select what the Security Policy is to do with packets that match this policy. Select deny to silently discard the packets without sending a TCP reset packet or an ICMP destination-unreachable message to the sender. Select reject to discard the packets and send a TCP reset packet or an ICMP destination-unreachable message to the sender. Select allow to permit the passage of the packets. |
Log matched traffic | Select whether to have the Zyxel Device generate a log (log), log and alert (log alert) or not (no) when the policy is matched to the criteria listed above. |
Profile | Use this section to apply anti- x profiles (created in the Security Services screens) to traffic that matches the criteria above. You must have created a profile first; otherwise none displays. Use Log to generate a log (log), log and alert (log alert) or not (no) for all traffic that matches criteria in the profile. |
Application Patrol | Select an Application Patrol profile from the list box; none displays if no profiles have been created in the Security Service > App Patrol screen. |
Content Filter | Select a Content Filter profile from the list box; none displays if no profiles have been created in the Security Service > Content Filter screen. |
SSL Inspection | Select an SSL Inspection profile from the list box; none displays if no profiles have been created in the Security Service > SSL Inspection screen. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to return the screen to its last-saved settings. |
name | address type | ip address |
Server | Host | 2.2.2.2 |
name | from | to | source | destination | service | action | log |
LAN_to_Device | LAN | ZyWALL | Server | Any | Ping | Allow | No |
label | description |
General Settings | |
Enable Anomaly Detection and Prevention | Select this to enable traffic anomaly and protocol anomaly detection and prevention. |
Add | Select an entry and click Add to append a new row beneath the one selected. ADP policies are applied in order (Priority) shown in this screen |
Edit | Select an entry and click this to be able to modify it. |
Remove | Select an entry and click this to delete it. |
Move | To change an entry’s position in the numbered list, select it and click Move to display a field to type a number for where you want to put that entry and press [ENTER] to move the entry to the number that you typed. |
Status | The activate (light bulb) icon is lit when the entry is active and dimmed when the entry is inactive. |
Priority | This is the rank in the list of anomaly profile policies. The list is applied in order of priority. |
Name | This is the name of the anomaly profile policy. |
From | This is the direction of travel of packets to which an anomaly profile is bound. Traffic direction is defined by the zone the traffic is coming from. Use the From field to specify the zone from which the traffic is coming. Select ZyWALL to specify traffic coming from the Zyxel Device itself. From LAN means packets traveling from a computer on one LAN subnet to a computer on another subnet via the Zyxel Device’s LAN1 zone interfaces. The Zyxel Device does not check packets traveling from a LAN computer to another LAN computer on the same subnet. From WAN means packets that come in from the WAN zone and the Zyxel Device routes back out through the WAN zone. ![]() |
Anomaly Profile | An anomaly profile is a set of anomaly policies with configured activation, log and action settings. This field shows which anomaly profile is bound to which traffic direction. Select an ADP profile to apply to the entry’s traffic direction. Configure the ADP profiles in the ADP profile screens. |
Profile Management | Create ADP profiles here and then apply them in the Security Policy > DoS Prevention > DoS Prevention Policy screen. |
Add | Click Add to create a new profile. |
Reference | Select an entry and click Reference to check which settings use the entry. |
Name | This is the name of the profile you created. |
Description | This is the description of the profile you created. |
Name | A name is automatically generated that you can edit. The name must be the same in the DoS Prevention screens for the same DoS prevention profile. You may use 1-31 alphanumeric characters, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. These are valid, unique profile names: • MyProfile • mYProfile • Mymy12_3-4 These are invalid profile names: • 1mYProfile • My Profile • MyProfile? • Whatalongprofilename123456789012 |
Description | In addition to the name, type additional information to help you identify this DoS prevention profile. |
Scan/Flood Detection | Scan detection, such as port scanning, tries to find attacks where an attacker scans device(s) to determine what types of network protocols or services a device supports. Flood detection tries to find attacks that saturate a network with useless data, use up all available bandwidth, and so aim to make communications on the network impossible. |
Sensitivity (Scan detection only) | Select a sensitivity level so as to reduce false positives in your network. If you choose low sensitivity, then scan thresholds and sample times are set low, so you will have fewer logs and false positives; however some traffic anomaly attacks may not be detected. If you choose high sensitivity, then scan thresholds and sample times are set high, so most traffic anomaly attacks will be detected; however you will have more logs and false positives. |
Block Period | Specify for how many seconds the Zyxel Device blocks all packets from being sent to the victim (destination) of a detected anomaly attack. Flood Detection applies blocking to the destination IP address and Scan Detection applies blocking to the source IP address. |
Edit (Flood Detection only) | Select an entry and click this to be able to modify it. |
Log | To edit an item’s log option, select it and use the Log icon. Select whether to have the Zyxel Device generate a log (log), log and alert (log alert) or neither (no) when traffic matches this anomaly policy. |
Action | To edit what action the Zyxel Device takes when a packet matches a policy, select the policy and use the Action icon. None: The Zyxel Device takes no action when a packet matches the policy. Block: The Zyxel Device silently drops packets that matches the policy. Neither sender nor receiver are notified. |
Name | This is the name of the anomaly policy. Click the Name column heading to sort in ascending or descending order according to the protocol anomaly policy name. |
Log | These are the log options. To edit this, select an item and use the Log icon. |
Action | This is the action the Zyxel Device should take when a packet matches a policy. To edit this, select an item and use the Action icon. |
Threshold (pkt/sec) | (Flood detection only.) Select a suitable threshold level (the number of packets per second that match the flood detection criteria) for your network. If you choose a low threshold, most traffic anomaly attacks will be detected, but you may have more logs and false positives. If you choose a high threshold, some traffic anomaly attacks may not be detected, but you will have fewer logs and false positives. |
Source IP Spoofing Prevention | |
Enable | Click to slide the switch to the right to enable IP spoofing prevention. |
Log | Select whether to have the Zyxel Device generate a log (log), log and alert (log alert) or neither (no) if a device connected to this interface attempts to use an IP address that is bound to another device’s MAC address. |
Enable Interface | Select the interface to enforce links between specific IP addresses and specific MAC addresses on this interface. This stops anyone else from manually using a bound IP address on another device connected to this interface. Use this to make use only the intended users get to use specific IP addresses. |
Trusted IP/MAC Pair | |
Include DHCP Leasing Entries | Enable this to allow traffic from devices that is listed in the current DHCP table. To manage the list of DHCP-assigned IP addresses, click Include DHCP Leasing Entries to go to the Network > DHCP Table screen. |
Add | Click this to create a new entry. |
Interface | This field displays the name of the interface within the Zyxel Device. |
IP Address | This is the IP address that the Zyxel Device assigns to a device with the entry’s MAC address. |
MAC Address | This is the MAC address of the device to which the Zyxel Device assigns the entry’s IP address. |
Description | This helps identify the entry. |
Trusted IP | |
Object Name | This is the name of the IP address object to allow traffic. |
Trusted IP | |
Object Name | Select an IP address object to allow traffic from all devices with that IP address. |
Session Control | Click to slide the switch to the right to enable session control. |
Default Session per Host | Use this field to set a common limit to the number of concurrent NAT/Security Policy sessions each client computer can have. ‘0’ means unlimited. If only a few clients use peer to peer applications, you can raise this number to improve their performance. With heavy peer to peer application use, lower this number to ensure no single client uses too many of the available NAT sessions. Create rules below to apply other limits for specific users or addresses. |
Remove | To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
Move to | To change a rule’s position in the numbered list, select the rule and click Move to to display a field to type a number for where you want to put that rule and press [ENTER] to move the rule to the number that you typed. The ordering of your rules is important as they are applied in order of their priority number. |
Priority | This is the priority of a session limit rule. Rules are applied according to priority number. |
User | This is the user name or user group name to which this session limit rule applies. |
Source IP | This is the IP address of the host to which this session limit rule applies. |
Description | This is the information configured to help you identify the rule. |
Limit | This is how many concurrent sessions this user or address is allowed to have. |
Enable | Click to slide the switch to the right to turn on this session limit rule. |
Description | Enter information to help you identify this rule. Use up to 60 printable ASCII characters. Spaces are allowed. |
User | Select a user name or user group to which to apply the rule. The rule is activated only when the specified user logs into the system and the rule will be disabled when the user logs out. Otherwise, select any and there is no need for user logging. ![]() |
Address | Select the IPv4/IPv6 source address (range) or address group, including geographic address (group) object, to which this rule applies. Select any to apply the rule to all IPv4 source addresses. |
Session Limit per Host | Use this field to set a limit to the number of concurrent NAT/Security Policy sessions this rule’s users or addresses can have. For this rule’s users and addresses, this setting overrides the Default Session per Host setting in the general Security Policy Session Control screen. |
Apply | Click Apply to save your customized settings and exit this screen. |
Cancel | Click Cancel to exit this screen without saving. |
