Troubleshooting
This chapter offers some suggestions to solve problems you might encounter. The potential problems are divided into the following categories.
Power, Hardware Connections, and LEDs
The Switch does not turn on. None of the LEDs turn on.
1 Make sure you are using the power adapter or cord included with the Switch.
2 Make sure the power adapter or cord is connected to the Switch and plugged in to an appropriate power source. Make sure the power source is turned on.
3 Disconnect and re-connect the power adapter or cord to the Switch.
4 If the problem continues, contact the vendor.
One of the LEDs does not behave as expected.
1 Make sure you understand the normal behavior of the LED.
2 Check the hardware connections.
3 Inspect your cables for damage. Contact the vendor to replace any damaged cables.
4 Disconnect and re-connect the power adapter or cord to the Switch.
5 If the problem continues, contact the vendor.
Switch Access and Login
I can see the Login screen, but I cannot log in to the Switch. (I forgot the user name and/or password.)
1 Check the Switch’s management mode by using the CLOUD LED.
If you are in Cloud management mode, use the Local credentials Password to log in to the cloud mode – local GUI. The Local credentials Password can be found in Site-wide > Configure > Site settings > Device configuration: Local credentials: Password in the NCC portal.
If you are in standalone management mode, use the default user name admin and the default password 1234.
2 Depending on your Switch’s management mode, make sure you have entered the correct user name and password. These fields are case-sensitive, please make sure [Caps Lock] is not on.
*Steps 1 and 2 are applicable if you get an invalid administrator password when using some functions in the ZON utility.
3 You may have exceeded the maximum number of concurrent Telnet sessions. Close other Telnet sessions or try connecting again later.
Check that you have enabled logins for HTTP or Telnet. If you have configured a secured client IP address, your computer’s IP address must match it. Refer to the chapter on access control for details.
4 If this does not work, or you are not sure what the Switch’s management mode is, you have to reset the device to its factory defaults (Standalone management mode) first. (Temporarily disconnect the Internet connection to the Switch after the reset process, to prevent the Switch from being managed by NCC again.)
*After performing step 4 and you want to use the Cloud management mode, make sure the Switch is registered in your organization and site in the NCC portal. To register the Switch again, scan the QR code using the Zyxel Nebula Mobile app.
I forgot the IP address for the Switch.
1 You can use the default IP address https://DHCP-assigned IP (when connecting to a DHCP server) or 192.168.1.1. When in Cloud mode, the DHCP-assigned IP address could be found in the NCC portal, in Site-wide > Devices > Switches (The Switch must be registered and added to a site in Nebula in order for it to be managed by Nebula).
*When your computer is directly connected to the Switch, you can always use the domain name setup.zyxel to access the Web Configurator. This requires your computer to be able to connect to a DNS server.
2 If the Switch is removed from a site in Nebula, all the settings in the configuration file are reset to the Nebula factory defaults except for the IP address. If you changed the default dynamic IP address to a static IP address while the Switch was in a site in Nebula, the Switch will retain that static IP address after you remove it from the site in Nebula.
3 Use the ZON utility to find the IP address.
4 If you are using the console/USB port, use the command line show ip to find the IP address.
5 If the Switch is removed from a site in Nebula, all the settings in the configuration file are reset to the Nebula factory defaults except for the IP address. If you changed the default dynamic IP address to a static IP address while the Switch was in a site in Nebula, the Switch will retain that static IP address after you remove it from the site in Nebula.
6 Use the console port to log in to the Switch.
7 If this does not work, you have to reset the device to its factory defaults.
I cannot see or access the Login screen in the Web Configurator.
1 Make sure you are using the correct IP address.
The default IP address is https://DHCP-assigned IP (when connecting to a DHCP server) or 192.168.1.1.
If you changed the IP address, use the new IP address.
If you changed the IP address and have forgotten it, see the troubleshooting suggestions for I forgot the IP address for the Switch.
2 Check the hardware connections, and make sure the LEDs are behaving as expected.
3 Make sure your Internet browser does not block pop-up windows and has JavaScripts and Java enabled.
4 Make sure your computer is in the same subnet as the Switch. (If you know that there are routers between your computer and the Switch, skip this step.)
5 Reset the Switch to its factory defaults, and try to access the Switch with the default IP address.
6 If the problem continues, contact Zyxel technical support, or try the advanced suggestion.
Advanced Suggestion
Try to access the Switch using another service, such as Telnet. If you can access the Switch, check the remote management settings to find out why the Switch does not respond to HTTP.
Pop-up Windows, JavaScripts and Java Permissions
In order to use the Web Configurator you need to allow:
Web browser pop-up windows from your device.
JavaScripts (enabled by default).
Java permissions (enabled by default).
There is unauthorized access to my Switch through telnet, HTTP and SSH.
Go to the MONITOR > System Log screen to check for logs of unauthorized access to your Switch. To avoid unauthorized access, configure the secured client setting in the SECURITY > Access Control > Remote Management screen for telnet, HTTP and SSH. Computers not belonging to the secured client set cannot get permission to access the Switch.
The Switch is already registered with NCC, but it is still in Standalone mode; it cannot connect to the NCC.
1 Make sure that NCC Discovery is enabled. Check the three NCC connection status circles on the DASHBOARD screen. All status circles display green (normal) when the Switch is connected and managed by NCC. If a circle displays orange (fails), hover a mouse over the circle to see diagnostic messages for troubleshooting. You can also go to the SYSTEM > Cloud Management screen to check the diagnostic messages.
2 Check your network’s firewall or security settings. Make sure the following TCP ports are allowed: 443, 4335, and 6667.
3 Make sure your Switch can access the Internet.
4 Make sure your Switch does not have to go through network authentication such as a captive portal, If your network uses a captive portal, the network administrator may have to create a new VLAN without this requirement. Change your Switch’s management VLAN settings as necessary.
Switch Configuration
I lost my configuration settings after I restarted the Switch.
Make sure you save your configuration into the Switch’s non-volatile memory each time you make changes. Click Save at the top right of the Web Configurator to save the configuration permanently.
I accidentally unplugged the Switch. I am not sure which configuration file will be loaded.
If you plug the power cable back to the Switch, it will reboot and load the configuration file that was used the last time. For example, if Config 1 was used on the Switch before you accidentally unplugged the Switch, Config 1 will be loaded when rebooting.
I want to use a different configuration file on the Switch, what should I do?
1 Go to MAINTENANCE > Configuration > Restore Configuration.
2 Click Choose File or Browse to locate the configuration file you wish to restore.
3 After you have specified the file, click Restore. The Switch will run on the restored configuration after the restore process.
I cannot access the NCC portal.
Check that you are using the correct URL:
Make sure your computer’s Ethernet card is installed and functioning properly.
Check that you have Internet access. In your computer, click Start, (All) Programs, Accessories and then Command Prompt. In the Command Prompt window, enter ‘ping’ followed by a website such as ‘zyxel.com’. If you get a reply, try to ping ‘nebula.zyxel.com’.
Make sure you are using the correct web browser that supports HTML5. View the browser in full screen mode to display the NCC portal properly. Browsers supported are:
Google Chrome
Microsoft Edge
Mozilla Firefox
I cannot log into the NCC portal.
Open your web browser and go to https://nebula.zyxel.com. If you do not have a Nebula Zyxel Account, click Create account and create an account.
If you already have an account but cannot login, click Forgot Password to reset the password.
Some features I set using the NCC do not work as expected.
1 Make sure your Switch can access the Internet.
2 Make sure the Switch’s Status displays “Online” in Site-wide > Devices > Switches on the NCC portal.
3 If the Switch is offline when the settings were changed, wait for ten minutes after the Switch goes back online.
4 After changing your Switch settings using the NCC, wait 1 – 2 minutes for the changes to take effect.
5 Check the Switch Configuration status in Site-wide > Devices > Switches on the NCC portal. The status should display “up to date”.
PoE Supply
My Powered Devices (PDs) are not receiving power.
1 Check the PoE usage of the Switch.
Check the PoE Usage on the Dashboard. This field displays the amount of power the Switch is currently supplies to the connected PDs and the total power the Switch can provide to the connected PDs. It also shows the percentage of PoE power usage. Or, see the PoE LED on the front panel of your Switch.
If the PoE usage exceeds the Switch’s PoE power budget, follow the step below to configure the PoE power or add another PoE-capable Switch for additional PDs.
2 Check the PoE configuration of the Switch.
Make sure the Active checkbox for the port supplying PoE power to PDs is enabled.
Check the Priority on the ports. When PoE usage reaches 100%, the Switch will shut down PDs one-by-one according to the PD Priority which you configured in PORT > PoE Setup > PoE Setup.
Check if you have set a pre-defined schedule to control when the Switch enables PoE to provide power on the port in PORT > PoE Setup > PoE Time Range Setup.
3 Make sure the PDs are functional.
Check whether the PDs are malfunctioning. See your PDs user’s guide for more information.
Make sure the connected PDs support PoE.
4 Make sure the Ethernet cables connected to the PDs are functional.
Use the correct type of Ethernet cable for the corresponding PoE standard you are using. See PoE for the Switch’s supported PoE standards and supported Ethernet cables.
Check whether the Ethernet cables are malfunctioning. Use functional Ethernet cables to reconnect the Switch to the PDs.
5 Disconnect and re-connect the power adapter or cord to the Switch (in AC models or if the AC power supply is connected in AC/DC models).
6 If the problem continues, contact Zyxel technical support.
Nebula Registration
I cannot register the Switch in Nebula because the previous owner has registered/locked it.
To register a pre-owned Switch in Nebula, use the Nebula Mobile app to scan the Nebula QR code on the back label of the Switch.
To register a pre-owned Switch in Nebula locked by the previous owner, inform the previous owner to remove the Switch from the Nebula organization or contact Zyxel technical support.
I no longer want to use Nebula to manage the Switch, what should I do?
Remove the Switch from the Nebula organization first. The Switch will reboot and restore its factory-default settings.
Make sure the CLOUD LED is off or blinking green. This means the Switch is operating in standalone mode. Nebula Control Center Discovery is disabled in SYSTEM > Cloud Management > Nebula Control Center Discovery in the Web Configurator.
