Label | Description |
Radio 1 Setting | |
Radio 1 Activate | Select the checkbox to enable the Zyxel Device’s first (default) radio. |
Radio 1 OP Mode | Select the operating mode for radio 1. AP Mode means the radio can receive connections from WiFi clients and pass their data traffic through to the Zyxel Device to be managed (or subsequently passed on to an upstream gateway for managing). Root AP means the radio acts as an AP and also supports the wireless connections with other APs (in repeater mode) to form a WDS (Wireless Distribution System) to extend its wireless network. Repeater means the radio can establish a wireless connection with other APs (in either root AP or repeater mode) to form a WDS. |
Radio 1 Profile | Select the radio profile the radio uses. |
Add ![]() | This button is not available after you configure the Zyxel Device using the wizard. Click the Add icon ( )to open a screen where you can create a new entry. For features where the entry’s position in the numbered list is important (features where the Zyxel Device applies the table’s entries in order like the SSID for example), you can select an entry and click Add to create a new entry after the selected entry. |
Radio 1 WDS Profile | This field is available only when the radio is in Root AP or Repeater mode. Select the WDS profile the radio uses to connect to a root AP or repeater. |
Enable WDS Wireless Bridging | If you set the Zyxel Device as a root AP, the radio that’s bridging with the Zyxel Device should be in repeater mode. Be careful to avoid bridge loops. For example, if your root AP and the Zyxel Device are connected to a switch, and they’re also connected to each other using a WiFi connection. This will create bridge loops. This field is available only when the radio is in Repeater mode. Select this to enable WDS wireless bridging on the Zyxel Device. See Zyxel Device Roles for more information on Wireless Distribution System (WDS). |
Uplink Selection Mode | This field is available only when the radio is in Repeater mode. Select AUTO to have the Zyxel Device automatically use the settings in the applied WDS profile to connect to a root AP or repeater. Select Manual to have the Zyxel Device connect to the root AP or repeater with the MAC address specified in the Radio 1 Uplink MAC Address field. |
Setup Wireless Bridge Vlan ID | This appears if you select Enable WDS Wireless Bridging. Click this to show the Wireless Bridge Vlan Setting pop-up window. This link is available only when the radio is in Root AP or Repeater mode. |
Wireless Bridge Vlan Setting | |
Add | Click this to add an entry in the table. |
Remove | Select an entry and click this to remove the selected entry. |
# | This field is a sequential value. It is not associated with any VLAN ID. |
Wireless Bridge Vlan ID | Enter a VLAN ID for the wireless bridge. The VLAN IDs you set on your root AP should be the same as the VLAN ID you set here. See Zyxel Device Roles for more information on wireless bridge. |
OK | Click OK to save your changes back to the Zyxel Device. |
Close | Click Close to close the pop-up window without saving your changes. |
Max Output Power | Enter the maximum output power (between 0 to 30 dBm) of the Zyxel Device in this field. If there is a high density of APs in an area, decrease the output power of the Zyxel Device to reduce interference with other APs. |
MBSSID Settings | |
Edit ![]() | Click the Edit icon ( )to open a screen where you can modify the entry’s settings. In some tables you can just click a table entry and edit it directly in the table. For those types of tables small red triangles display for table entries with changes that you have not yet applied. |
# | This field shows the index number of the SSID |
SSID Profile | This field displays the SSID profile that is associated with the radio profile. |
Band | This field displays the frequency bands to which the SSID profile is applicable. If the SSID profile is not applicable to the current radio, the SSID profile will not be enabled. You can configure the SSID profile’s applicable frequency bands in the Edit SSID Profile screen (click the Edit button next to the profile). |
Radio 2 Setting | |
Radio 2 Activate | This displays if the Zyxel Device has a second radio. Select the checkbox to enable the Zyxel Device’s second radio. |
Radio 2 OP Mode | This displays if the Zyxel Device has a second radio. Select the operating mode for radio 2. AP Mode means the radio can receive connections from WiFi clients and pass their data traffic through to the Zyxel Device to be managed (or subsequently passed on to an upstream gateway for managing). Root AP means the radio acts as an AP and also supports the wireless connections with other APs (in repeater mode) to form a WDS to extend its wireless network. Repeater means the radio can establish a wireless connection with other APs (in either root AP or repeater mode) to form a WDS. |
Radio 2 Profile | This displays if the Zyxel Device has a second radio. Select the radio profile the radio uses. |
Radio 2 WDS Profile | This field is available only when the radio is in Root AP or Repeater mode. Select the WDS profile the radio uses to connect to a root AP or repeater. |
Setup Wireless Bridge Vlan ID | Click this to show the Wireless Bridge Vlan Setting pop-up window. This link is available only when the radio is in Root AP or Repeater mode. |
MBSSID Settings | |
Edit ![]() | Click Edit ( )to open a screen where you can modify the entry’s settings. In some tables you can just click a table entry and edit it directly in the table. For those types of tables small red triangles display for table entries with changes that you have not yet applied. |
SSID Profile | This field shows the SSID profile that is associated with the radio profile. |
Band | This field displays the radio bands to which the SSID profile is applicable. If the SSID profile is not applicable to the current radio, the SSID profile will not be enabled. You can configure the SSID profile’s applicable radio bands in the Edit SSID Profile screen (click the Edit button next to the profile). |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
Rogue AP Detection Setting | |
Enable Rogue AP Detection | Select this checkbox to detect Rogue APs in the network. |
Suspected Rogue AP Classification Rule | Select the checkboxes (Weak Security (Open, WEP, WPA-PSK), Hidden SSID, SSID Keyword) of the characteristics an AP should have for the Zyxel Device to mark it as a Rogue AP. |
Add | Click this to add an SSID Keyword. |
Edit | Select an SSID Keyword and click this button to modify it. |
Remove | Select an existing SSID keyword and click this button to delete it. |
# | This is the SSID Keyword’s index number in this list. |
SSID Keyword | This field displays the SSID Keyword. |
Rogue/Friendly AP List | |
Add | Click this button to add an AP to the list and assign it either friendly or rogue status. |
Edit | Select an AP in the list to edit and reassign its status. |
Remove | Select an AP in the list to remove. |
# | This field is a sequential value, and it is not associated with any interface. |
Role | This field indicates whether the selected AP is a rogue-ap or a friendly-ap. To change the AP’s role, click the Edit button. |
MAC Address | This field indicates the AP’s radio MAC address. |
Description | This field displays the AP’s description. You can modify this by clicking the Edit button. |
Rogue/Friendly AP List Importing/Exporting | These controls allow you to export the current list of rogue and friendly APs or import existing lists. |
File Path / Browse / Importing | Enter the file name and path of the list you want to import or click the Browse button to locate it. Once the File Path field has been populated, click Importing to bring the list into the Zyxel Device. You need to wait a while for the importing process to finish. |
Exporting | Click this button to export the current list of either rogue APs or friendly APS. |
MAC | Enter the MAC address of the AP you want to add to the list. A MAC address is a unique hardware identifier in the following hexadecimal format: xx:xx:xx:xx:xx:xx where xx is a hexadecimal number separated by colons. |
Description | Enter up to 60 characters for the AP’s description. Spaces and underscores are allowed. |
Role | Select either Rogue AP or Friendly AP for the AP’s role. |
Cancel | Click Cancel to close the window with changes unsaved. |
DCS Now | Click this to have the Zyxel Device scan for and select an available channel immediately. |
